Disabled all pins not connected?
Motors working correctly?
Any unexpected sensor triggering?
Some sensor not triggering?
Bluetooth not connecting?
Console output
 START
 Ardumower rXXXX
 press...
   d for menu
In the Serial Console you got many Information about your Robot. Here ist what it means :
--- Messages from the serial ---
- After-home-drive? (1/0)
sen - current timeout counter engine: left, right, Mower
bum - Bumpercounter: left, right
pit / roll - inclination (calculated with Accel sensor)
com - Compass Course
by - inductive loop detector: counter
bat - Battery voltage
chg - charging current
--- Menu Konsole ---
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
  1. Diagnostic
