Motors working correctly?
Any unexpected sensor triggering?
Some sensor not triggering?
Bluetooth not connecting?
Console output
In the Serial Console you got many Information about your Robot.
Here ist what it means :
--- Messages from the serial ---
v - Verbose mode selected sensor (0 = counts / 1 = sensor values / 2 = sensor values)
- After-home-drive? (1/0)
sen - current timeout counter engine: left, right, Mower
bum - Bumpercounter: left, right
pit / roll - inclination (calculated with Accel sensor)
com - Compass Course
by - inductive loop detector: counter
bat - Battery voltage
chg - charging current
--- Menu Konsole ---
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
