Everything under development here. Just showing ideas! :-)
Sensor fusion is used to eliminate errors of each individual sensor. Each sensor gets a confidence weight that is automatically adjusted after reading the sensor by comparing its plausibility with the fusion result.
Sensor errors
  • Odometry: accumulation error (e.g. 15cm per meter), update rate: 10-20 Hz
  • Gyro: accumulation error (e.g. 1 degree per second), update rate: 10-20 Hz
  • Compass: noise (e.g. 1 degree), update rate: 10-20 Hz
  • GPS: noise (e.g. 2m), update rate: 1-5 Hz
Odometry sensor error
  • Distance: 20cm per meter
  • Course: 10 degree per meter
  1. Calculation of short-time position by Odometry and Compass
  2. Calculation of long-term position via GPS
A Kalman filter can be used to fuse all sensor values.
Position recalibration
  1. Learn mode: robot completely tracks perimeter wire once and saves course (degree) and distance (odometry ticks) in a list (perimeter tracking map).
  2. Position detection: robot starts tracking the perimeter wire at arbitrary position until a high correlation with a subtrack of the perimeter tracking map is found. There it can stop tracking and knows its position on its perimeter tracking map.
Mapping and localization (SLAM)
Input to SLAM algorithm:
  • control values (speed, steering)
  • observation values (speed, heading, magnetic field strength)
Output from SLAM algorithm:
  • magnetic field map (including perimeter border)
  • robot position on that map (x,y,theta)
Example SLAM algorithms:
  • Particle filter-based SLAM plus Rao-Blackwellization: model the robot’s path by sampling and compute the 'landmarks' given the poses
Lane-by-lane mowing
Simulation
