- 1 Raspberry Pi
- 1.1 Setup
- 1.2 Piardu Configuration
- 1.4 Piardu MENU Description
Raspberry Pi
Setup
What you need
Fast setup for Advanced user
Here the full setup process:
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
Pi Software part
sudo apt-get update
sudo apt-get upgrade
Python3 Idle
Pygame
Paho Mqtt
What you can send to mower
Topic Denna/COMMAND
payload : STOP to stop
payload : HOME to go station
What you receive from mower
Send only when value change
Topic Denna/STATUS payload the mower status see robot.py list for possible value Topic Denna/STATE payload the mower state see robot.py list for possible value Topic Denna/Battery payload the bat voltage Topic Denna/Temp payload the mower temp Topic Denna/Battery payload the bat voltage
Topic Denna/Idle payload the loop per second of due
KST Plot
DosToUnix
Arduino IDE
Warning : folder arduino-1.8-13 can change over time for example arduino-1.8-15 , so use the correct name according your download in the next command.
cd Downloads/arduino-1.8.13
sudo ./install.sh
PiArdu Software
Using VNC Viewer :
cd Documents
cd PiArdumower
cd Documents/PiArdumower
dos2unix Restart.py
cd ~/Desktop
dos2unix mower.sh
Automatic start on Power up:
DUE Connection
With DC/DC regulator
FLASH DUE
CHECK COMMUNICATION
change with:
Optional Screen
cd LCD-show/
sudo ./LCD5-show
Optional Camera
Check to Enable the Camera
Expérimental AI Vision with Tensorflow
Fast main setup description.
core data protos ssdlite_mobilenet_v2_coco_2018_05_09 utils vision
Now in a new terminal :
sudo apt-get update
Install OPENCV
Install Tensorflow
pip3 install tensorflow
Backup SD CARD
Download the soft and start it.Your SDCARD is normaly detected and you only need to select a backup folder and give a name to the file ,add .img at the end of your backup file
TO BACKUP
TO RESTORE
PCB part:
GPS part:
Arduino Nano part.
NanoConnectedOnPi
Battery part:
AutoRecordBatCharging
Debug part:
UseDebugConsole
Sender part:
Camera part:
myCamAngle
streamVideoOnPower
Power ON
https://youtu.be/Qhv8r2bD_Bk
Power OFF
https://youtu.be/4YJQ-zyLq-Q
It's here :
[[1]]
