Ardumower Sunray
- 4 Requirements
- 8 PCB1.3 GPS pin fix and wire fix
- 9 PCB1.3 odometry divider
- 11 RTK base
- 12 RTK rover
- 15 Phone App
- 16 Odometry test
- 17 Position source mode
- 22 GPS checksum errors
- 25 IMU, sensor fusion
- 26 Ultrasonic sensor
- 27 Bumper sensor
- 28 Extending WiFi range with outdoor access point
- 29 Portable WiFi router for NTRIP
- 30 Charging process, longer battery operation time
- 31 Automatic robot switch off
- 32 Docking
- 33 WiFi module
- 34 Bluetooth Low Energy (BLE) and WiFi external antenna
- 35 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 36 Troubleshooting
- 37 How to record GPS data
- 38 Datasheets
- 39 Data privacy
- 40 Discussion / questions / forum thread
- 41 SD card module
- 42 SD card logging
- 43 R/C model
- 44 Hardware debugging
- 45 XBee module configuration
- 46 Firmware Console Debugging
- 47 Further links
To be able to use RTK-GPS, your robot mower should have a good and open view to the sky at all locations (see photo below). RTK-GPS will NOT work under extreme limited sky view, near walls, in buildings, in narrow areas with larger obstacles all around. There should be at least 10x10m free space on the lawn (without walls and trees) to get a robust RTK fix solution on the complete lawn.
Please follow the steps described at the main page for assembling chassis, motors, docking station etc. and PCB1.3. After you have assembled the chassis and PCB you can follow the steps below for the RTK functionality.
It requires Ardumower kit mowing and gear motors, PCB1.3, Adafruit Grand Central M4(or Arduino Due), Ardumower RTK kit, Bluetooth BLE and a phone (Android/iOS).
- Optimized for Ardumower kit mowing and gear motors and PCB 1.3
- Remove jumper Gps_S (JP12)
| PCB 1.3 | PCB 1.4 |
F0-00 F0-00 NMEA GxGGA 60
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
- South America: 433 MHz
- Africa: 433 MHz
- Asia: 415/433 MHz
- New Zealand: 917-927MHz
- Start XCTU
