Ardumower Sunray
- 4 Requirements
- 8 PCB1.3 GPS pin fix and wire fix
- 9 PCB1.3 odometry divider
- 11 RTK base
- 12 RTK rover
- 15 Phone App
- 16 Odometry test
- 17 Position source mode
- 22 GPS checksum errors
- 25 IMU, sensor fusion
- 26 Ultrasonic sensor
- 27 Bumper sensor
- 28 Extending WiFi range with outdoor access point
- 29 Portable WiFi router for NTRIP
- 30 Charging process, longer battery operation time
- 31 Automatic robot switch off
- 32 Docking
- 33 WiFi module
- 34 Bluetooth Low Energy (BLE) and WiFi external antenna
- 35 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 36 Troubleshooting
- 37 How to record GPS data
- 38 Datasheets
- 39 Data privacy
- 40 Discussion / questions / forum thread
- 41 SD card module
- 42 SD card logging
- 43 R/C model
- 44 Hardware debugging
- 45 XBee module configuration
- 46 Firmware Console Debugging
- 47 Further links
It requires Ardumower kit mowing and gear motors, PCB1.3, Adafruit Grand Central M4(or Arduino Due), Ardumower RTK kit, Bluetooth BLE and a phone (Android/iOS).
- Optimized for Ardumower kit mowing and gear motors and PCB 1.3
- Remove jumper Gps_S (JP12)
| PCB 1.3 | PCB 1.4 |
F0-00 F0-00 NMEA GxGGA 60
Remember: Set PCB1.3 jumper JC2 (I2C signal level) to 3.3V for IMU connector (if not set correctly you may experience I2C issues)
1. Connect PCB1.3_I2C2_VCC(5V/3.3V) to IMU VCC (set PCB1.3 JC2 jumper to 3.3V)
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
- South America: 433 MHz
- Africa: 433 MHz
- Asia: 415/433 MHz
- New Zealand: 917-927MHz
- Start XCTU
